airbagfolds
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- angle
- The angle with which moving side of airbag would rotate for simple fold.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity associated with airbag fold type.
- currentaflag
- Determines if the fold is current.
- definedentity
- True if the entity is defined, false otherwise.
- endcoords
- The location of the inclination point of folding line/axis.
- envelopelementnb
- The number of elements connecting the upper and lower envelope at critical position when config=3.
- envelopelementsize
- The size of element of envelope for simple fold.
- envelopelimiter
- The height ratio between upper and lower envelopes till which the envelope elements are created near folding axis of airbag for simple fold.
- fixedsidewidth
- The width of rigid plate at fixed side of airbag.
- foldtype
- The type of simple fold method used.
- h3dfile
- The file path to the h3d result file stored after solver run.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- interfriction
- The friction value of contact between airbag and envelope in case of simple fold.
- internalid
- internalname
- The internal name of the entity.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- parentairbagfs
- The parent airbag folding sequence entity.
- platesdistance
- The distance between 2 consecutive plates of zigzag folding.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- readh3dfile
- Flag to activate loading the result from the file referenced in h3dfile data name.
- rollnos
- The number of 180-degree rolling rotations applied in imposed displacement.
- rollradius
- The radius of cylindrical rolling tool.
- rollstopposition
- The location at which rolling fold will stop.
- rolltype
- The type of rolling tool created in rolling fold.
- rollwidth
- The width of the scale rolling tool.
- sidenode
- The node entity on one the side of the airbag which will be moving.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- startcoords
- The location of the base point of folding line/axis.
- tucknodes
- The list of nodes which will be used in imposed displacement which will be tucked between upper and lower tuck tools.
- voidcomponent
- Stores true if void elements between moving and fixed envelope is created, 0 otherwise.
- voidlimiter
- The height ratio between upper and lower envelopes until which the void elements are created near the folding axis of airbag for simple fold.
- zigzagplates
- The number of zigzag plates created for folding.
- zigzagtype
- The type of method used to create a zigzag fold.
Version History
2021.1
2021.2 - Added new data names internalname and solvername.
