Train Models
Train models using any physics, any mesh, and without design variable parametrization.
Note: Training times vary significantly depending on various factors, such as:
  • Inclusion of a Dataset (number of samples and number of elements and time steps per sample)
  • Model specifications (model size, hyperparameters, number of training epochs)
  • Hardware (processor speed, RAM, access to GPU)
Training can also be done on an HPC. See Train Remotely on an HPC for more information.
  1. From the PhysicsAI ribbon, select the Train an ML Model tool.
    The Train Model dialog opens.
  2. Define the training details and click Train.
    1. Enter a model name.
    2. For Training Data, select the created or existing Train Dataset.
    3. Select Inputs and Outputs.
    4. Specify the Epochs, the number of times the data needs to train.
      The Model Training dialog opens.
  3. Review the status in the Status column.
    Tip: Once the status changes to Running, you can view the training logs by clicking Show Log.
    Figure 3.
Train a PhysicsAI model on a remotely on a different machine than the one running the PhysicsAI GUI.
To train models remotely, you will need:
  • Access to a remote machine with the Engineering Data Science (EDS) application installed
  • PuTTY installed on your local machine
  • A training script (details below)
  • A mapped drive which can be accessed by both your local machine and the HPC. This is required so that your locally created datasets are visible to the HPC during training.
A common reason for remote training is to harness an HPC with a GPU, which can accelerate training significantly.
  1. Install the EDS application from the AltairOne Marketplace to your HPC.
  2. Create an SSH connection.
    1. Launch PuTTY on your local machine and connect to the HPC via SSH.
    2. Save the connection, for example: my_physicsAI_hpc.
    Important: If you are required to enter a password while logging in via PuTTY, you will need to setup RSA keys before continuing. Once you can login via PuTTY without entering a password, you may continue.
  3. Write a training script for your HPC using the following template.
    Your script should have the .bat extension if your local machine is running Windows. If your local machine is running Linux, your script should have the .sh extension.
    This example uses the qsub command from PBS.
    @echo off
    SETLOCAL
    REM ------------------------------------------------------------------------------
    REM Copyright (c) 2021 - 2021 Altair Engineering Inc.  All Rights Reserved
    REM Contains trade secrets of Altair Engineering, Inc.  Copyright notice
    REM does not imply publication.  Decompilation or disassembly of this
    REM software is strictly prohibited.
    REM USER SETTINGS
    REM HPC Setup
    set sess=<<HOST NAME>>
    set user=<<USER NAME>>
    REM PBS Requests
    set pbs_requests=-q a100 -N physicsAI_shape  -j oe -l select=1:ncpus=8:mem=257940mb:ngpus=1
    REM Windows -> Unix Mapping
    set win_map=\\<<SERVER IP>>\data\ds
    set unix_map=/data/ds
    REM PhysicsAI Installation Settings
    set install_loc=<<HW INSTALL LOCATION>>hwdesktop/hw/eds/bin/linux64/edspy.sh
    REM PBS Install Location
    set sub_cmd=/altair/pbsworks/pbs/exec/bin/qsub
    REM SCRIPT START
    REM Get whole input line
    set line=%*
    REM Map windows paths to unix
    set unixmap=%win_map%=%unix_map%
    set unixmap=%unixmap:\=/%
    set submit_line=%line:\=/%
    setlocal EnableExtensions EnableDelayedExpansion
    set submit_line=!submit_line:%unixmap%!
    echo %line%
    echo ---UNIXMAP---
    IF ["%unixmap%"] == [""] GOTO :RUN
    :RUN
    echo ---PLINK SETTINGS---
    echo user = %user%
    echo sess = %sess%
    echo ---PAI-SHAPE SETTINGS--
    echo install_loc = %install_loc%
    echo submit_line = %submit_line%
    REM Run QSUB
    set qsub_command_string='%install_loc% %submit_line%'
    REM Write File for submission
    echo plink -load %sess% -l %user% -batch "echo %qsub_command_string% > pai_qsub.txt"
    REM Submit file
    plink -load %sess% -l %user% -batch "%sub_cmd% %pbs_requests% pai_qsub.txt"
    echo plink -load %sess% -l %user% -batch "qsub %pbs_requests% pai_qsub.txt"
    ENDLOCAL
  4. Register the training script.
      Figure 4.
    2. For Training Script, select Register Training Script.
      The Add Training Script dialog opens.
    3. Click and browse and select your training script.
    4. Enter a name for your script and click OK.
    5. Close the Train Model dialog.
    Your preferences are saved and the physicsai_solver_prefs.json file in your user directory has been updated.
  5. Launch a remote training.
    1. Create a physicsAI project and dataset.
      See Create and Load Projects and Create and Manage Datasets for more information.
      Note: Ensure the project is located on a mapped drive that can be accessed by both your local machine and HPC.
    2. Repeat step 4.a to open to the Train Model dialog.
    3. Define the training details.
    4. For Training Script, select the training script you registered.
    5. Click Train.
    Your training script is invoked with the specified training dataset and model settings.
    A training will begin running on your HPC.
Train Using a GPU
Training a PhysicsAI model on a GPU is significantly faster. To train a model on a GPU, locally or on an HPC, you must complete the following steps.
  1. Install the NVIDIA CUDA toolkit and Deep Neutral Network library (CuDNN).
    Once these tools are installed, the GPU will be used by default for both training and predicting. You can verify this in the Task Manager by enabling the cuda graph in the GPU Performance tab.
  2. To use the CPU again, set CUDA_VISIBLE_DEVICES=-1 as an environment variable.
