When you start with a model with solids, then this macro will be used to generate mesh for components assigned Polymer materials. All the components assigned polymer material is displayed and its corresponding estimated element size and length estimated is displayed. You can edit the element sizes suitably. Also Profile length can be modified if the analysis is Extrusion.
