This chart lists some typical properties for metal forming materials.
This information adapted from the High Strength Steel Stamping Design Manual, copyright 1994, Auto/Steel Partnership.
Material  |
Grade  |
Yield Strength (ksi)  |
Tensile Strength (ksi)  |
Total Elong (%)  |
n value  |
r value  |
Hardness   |
Width Range   |
Thickness Range  |
HR  |
DQSK  |
34.0  |
48.0  |
42  |
0.20  |
1.1  |
54  |
24 to 72  |
.055-.375  |
HR  |
DQ  |
35.7  |
49.1  |
40  |
0.19  |
1.1  |
55  |
24 to 72  |
.055-.375  |
HR  |
CQ  |
38.9  |
56.0  |
39  |
0.19  |
NA  |
60  |
24 to 72  |
.055-.375  |
CR  |
EDDQ  |
20.0  |
44.0  |
49  |
0.26  |
1.9  |
30  |
24 to 72  |
.015-.080  |
CR  |
DQSK  |
26.5  |
45.0  |
44  |
0.23  |
1.8  |
36  |
24 to 72  |
.015-.130  |
CR  |
DQ  |
27.0  |
45.8  |
42  |
0.22  |
1.6  |
40  |
24 to 72  |
.015-.130  |
CR  |
CQ  |
30.2  |
47.0  |
41  |
0.20  |
1.3  |
45  |
24 to 72  |
.015-.130  |
HDG(CR)  |
EDDQ  |
22.4  |
44.9  |
46  |
0.25  |
1.9  |
32  |
24 to 72  |
.015-.170  |
HDG(CR)  |
DQSK  |
28.4  |
45.8  |
44  |
0.23  |
1.6  |
40  |
24 to 72  |
.015-.170  |
HDG(CR)  |
DQ  |
35.7  |
49.6  |
41  |
0.20  |
1.3  |
52  |
24 to 72  |
.015-.170  |
HDG(CR)  |
CQ  |
40.6  |
53.0  |
35  |
0.17  |
1.2  |
58  |
24 to 72  |
.015-.170  |
GA (CR)  |
EDDQ  |
22.0  |
44.7  |
48  |
0.25  |
1.9  |
32  |
24 to 72  |
.015-.170  |
GA (CR)  |
DQSK  |
24.5  |
46.0  |
45  |
0.22  |
1.6  |
45  |
24 to 72  |
.015-.170  |
GA (CR)  |
DQ  |
32.3  |
47.6  |
42  |
NA  |
NA  |
49  |
24 to 72  |
.015-.170  |
GA (CR)  |
SQ30  |
36.0  |
51.9  |
37  |
NA  |
NA  |
55  |
24 to 72  |
.020-.170  |
Alum(CR)  |
IF  |
25.0  |
44.0  |
43  |
0.24  |
1.7  |
37  |
24 to 60  |
.015-.140  |
Alum(CR)  |
EDDQ  |
26.0  |
44.0  |
46  |
0.24  |
1.6  |
39  |
24 to 60  |
.015-.140  |
Alum(CR)  |
DDQ1  |
26.0  |
44.0  |
45  |
0.21  |
1.3  |
45  |
24 to 60  |
.015-.140  |
Alum(CR)  |
DQSK  |
32.0  |
50.0  |
39  |
0.21  |
1.2  |
47  |
24 to 60  |
.015-.140  |
Alum(CR)  |
DQ  |
34.0  |
49.0  |
41  |
0.21  |
1.2  |
47  |
24 to 60  |
.015-.140  |
Alum(CR)  |
CQ  |
47.0  |
56.0  |
32  |
NA  |
1.2  |
60  |
24 to 60  |
.015-.140  |
