The transitory response of a perfect gas in a long tube separated into two parts using a diaphragm is studied. The
problem is well-known as the Riemann problem. The numerical results based on the finite element method with the Lagrangian
and Eulerian formulations, are compared to the analytical solution.
A supersonic flow encounters two successive wedges and oblique shock are
formed.
図 1.
The double oblique shock is a classic example in compressible fluid mechanics. It
involves a supersonic flow propagating along a wall with two unequal wedges. Each
wedge slows down and compresses the flow with the formation of a shock wave. These
two shocks then merge into a stronger, single one away from the wall, and a contact
wave is formed inside the flow between the shocked states. The numerical results
obtained for the thermodynamics quantities in each state of the flow can be compared
to analytical values obtained with compressible fluid mechanics theory.
注: The keywords not supported by HyperMesh are
in a separate include file. To view the file in HyperMesh, it is recommended to import the file using the
“Include File: Skip” option.
Model Description
A supersonic wind tunnel (100mm length, 50 mm height) is filled with a supersonic
flow Machine number (M=3) of air.
The lower wall includes two wedges of 8 degrees and 28 degrees.
The two wedges slow the flow down with the formation of shock waves. 図 2. Problem Description for Double Oblique Shock
Units: mm, ms, g, N, MPa
Model Method
The fluid domain is meshed with 2D quads elements with an average mesh size of
0.15*0.15 mm. This accounts for around 160,000 elements.
The material law used for air is a hydrodynamic fluid (/MAT/LAW6)
in combination with an ideal gas equation of state
(/EOS/IDEAL-GAS).
The hydrodynamic fluid (/MAT/LAW6) is used within a multi-fluid
law (/MAT/MULTILFUID) which uses a Finite Volume solver. The
fluid is considered non-viscous.
Air is defined with the following characteristics:
/MAT/LAW6
Initial density
1.225E-6
/EOS/IDEAL-GAS
Heat capacity ratio
1.4
Initial pressure
0.1 MPa
Since there is only one fluid (air), the multi-material law only integrates the air
defined using LAW6, with a volumer fraction of 1.
EULER property formulation with Iale
= 2 was used.
Boundary Conditions
図 3. Boundary Condition for Double Oblique Shock
The fluid is given an initial velocity along the z-axis, defined with
/INIVEL/FVM as:(1)(2)(3)
The value of velocity corresponds to a speed of Mach 3, with the Mach
number defined as:(4)
Where, is the sound velocity, which is computed
as:(5)(6)
When using /MAT/MULTIFLUID, the default boundary conditions are
sliding walls.
A non-reflecting inlet is defined using /EBCS/INLET/VP. Input
density and pressure are defined for the air in the multi-material law.
A non-reflecting boundary is defined with /EBCS/FLUXOUT.
Engine Control
As of the Radioss 2019.0 release, the critical time step
scale factor for all ALE and EULER elements defaults to 0.5, which is the
recommended value.
It can be modified using the keyword
/DT/ALE:
/DT/ALE
0.5 0.0
Results
It is interesting to take a look at pressure element velocity and density once
steady-state is reached. 図 4. Contour for Elemental Velocity 図 5. Contour for Elemental Pressure and Pressure Path
The Schlieren contour highlights the shock fronts. To improve the view of the shock
waves from the Schlieren output, advanced math was used in HyperView. The /H3D/ELEM/SCHLIEREN output
was raised to the 5th power and the legend changed to greyscale with
black at the minimum and white for the maximum value. 図 6. Schlieren Output to the Power of (5/density)
The shock front shown in 図 7 divides the flow into four states as each
shock front slows down and recompresses. 図 7. Shock Fronts and Density Map Showing the different
States
Fluid particles close to the wall go through two shock fronts, while those away from
the wall see only one. However, it is stronger, so flow quantities in State 3 differ
from State 2. State 2 and State 4 are separated by a verification wave 5, which
allows for a pressure equilibrium between States 3 and 4. All other quantities are
otherwise discontinuous between State 3 and State 4, as the two are separated by a
contact wave.
Results obtained from the simulation can be compared to the values obtained
analytically.
Analytical Analysis
The shocks are created by the two wedges. These two obstacles slow down and
re-compress the flow as it changes direction and becomes parallel to the wedge. With
supersonic flows, this process happens through an oblique shock wave, a stationary
discontinuity which separates a pre-shock state (State 1), where the fluid is in
this problem moving along the z-axis, from a post-shock state (State 2), with
increased pressure and mass density, but a lower velocity, as well as a new
direction, parallel to the wedge. 図 8. Deflection of Supersonic Flow through an Oblique
Shock
The theoretical values of thermodynamic quantities in every state can be determined
analytically.
First, determine the angle of the shock , from the flow Mach number and the wedge angle , by solving:(7)
Rankine-Hugoniot Jump formulas for the oblique shock are then used to obtain the
values in post-shock state:(8)(9)
All the physical properties in State 1 and State 2 can thus be determined.
The determination of State 3 and State 4 is more complex. Stage 3 is separated from
State 0 by a single oblique shock wave. However, this shock wave is not generated by
a single wedge of known angle, but rather by the combination from the two other
shocks.
The pressure in State 2 and 3 is not the same because the flow went through two
successive oblique shock waves, instead of through one stronger shock front. A
verification process will happen after State 2 until the pressure has decreased to
its value in the adjacent State 3.
State 3 and 4 needs to be determined together. State 3 is obtained from a flow
initially in state 0 that encounters an oblique shock (which angle in unknown) and shares the same pressure that State
4. The State 4 pressure is obtained after an isentropic verification from State 2,
in which the Mach number of the flow changes from to .
The value of pressure in these two states is thus obtained by finding solutions of
the following system (with = ), and the unknowns are and .
Oblique shock of angle between State 0 and State 3.
図 9. Mach Value Contour . w/o possible node paths going through every state of the flow
Isentropic verification process from State 2 to State 4.
With and determined, the other thermodynamics variables in
State 4 are determined considering an isentropic rarefaction process from State 2 to
State 4, and for State 3, by considering an oblique shock with an angle.
The solution of the double wedge problem using the shock polar. 1
表 1. Analytical Results
State 1
State 2
State 3
State 4
Shock angle [deg]
25.611
41.582
48.586
no shock
Mach number
2.603
1.722
1.537
1.746
Pressure [MPa]
0.180
0.595
0.574
0.574
Mass density
1.85E-06
4.15E-06
3.70E-06
4.04E-06
Numerical Results with Analytical Values Comparison
Numerical results for the thermodynamic variables can be read by drawing two node
paths along two current lines, one close to the wall and going through State 1, 2
and 4, and the other further away from the wall, going from State 0 to State 3
(図 9).
To draw node paths, the elemental results visible on the animation have to be
averaged at the nodes, using for example the averaging method simple.
The spatial profile for pressure and mass density on these two nodes paths are
visible on 図 10 and 図 11. Each flat on the curves corresponds to one
the flow states described above. The value of the thermodynamic quantities obtained
from the model can then be compared to those determined analytically. 図 10. Pressure Profile in Steady-State. with the value of the relative error to the analytical value 図 11. Mass Density Spatial Profile in Steady-State. with the value of the relative error to the analytical value
Analytical and numerical values for the flow Mach number in each state of the flow
are compared.
表 2. Analytical and Numerical Results for the Mach
number
Analytical
Numerical
Relative Error (%)
State 1
2.603
2.607
0.14
State 2
1.722
1.717
0.32
State 3
1.537
1.529
0.56
State 4
1.746
1.746
0.05
The relative error between numerical and analytical values for pressure, mass density
and Mach number are for every state inferior to 1%.
Conclusion
Supersonic flow is modeled using a
/MAT/LAW6 hydrodynamic fluid law, associated with an ideal
gas equation of state (/EOS/IDEAL-GAS), within a multi-fluid
material /MAT/LAW151 to use the finite volume solver.
As
the flows encounters two wedges, three stationary shock waves and a contact wave are
formed within the flow. The value of the flow physical parameters in each state can
be determined analytically.
The analytical approach shows a good correlation
between theoretical and numerical results.
The shocks and contact wave are
rendered well on the simulation. The use of /MAT/MULTIFLUID
allows for an accurate modeling of the dynamics of supersonic flows.
1 R.
Courant, K.O. Friedrichs, Supersonic Flow and Shock Waves, Springer-Verlag,
1998
