RD-HM-T: 1060 Three Point Bending Model Setup
This tutorial demonstrates how to set up a 3-point bending model consisting of a head profile and a closing plate.
This validation test is a common test to determine the bending strength during bending load. The usage of the head profile structures is a common design feature in automotive and aero industry.
図 1.
In this lesson you will learn to:
  • Step 1: Import Solverdeck
  • Step 2: Check /BEGIN card
  • Step 3: Define material
  • Step 4: Assign material
  • Step 5: Define property
  • Step 6: Assign property
  • Step 7: Create solid spotweld
  • Step 8: Define failure /FAIL/CONNECT
  • Step 9: Define rigid body
  • Step 10: Create boundary condition
  • Step 11: Create imposed velocity
  • Step 12: Set contact
  • Step 13: Define output (time history / anim)
  • Step 14: Create Engine setup and export the model
  • Step 15: Run the model and check the results in HyperView and HyperGraph
Model Description
The model set up consists of:
  • Material creation (with strain curve creation) and assignment:
    • Elasto-plastic material /MAT/LAW36 (plastic):
      • [Rho_I] Initial density = 7.85e-09 (ton/mm3)
      • [nu] Poisson’s ratio = 0.29
      • [E] Young’s modulus = 210000 (MPa)
  • UNITS: Length (mm), Time (s), Mass (t)
  • Simulation time: [0 – 7.01E-02]
  • Boundary Conditions: The supports are all fixed. An imposed velocity of 1000.0 mm/s is applied on the impactor.
  • Model size: 370mm x 46.5mm x 159mm
Prerequisites
To run this simulation, you will need access to a licensed version of Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
開始する前に、このチュートリアルで使用するファイルを作業ディレクトリにコピーします。
Tutorial Video
