ACDISP
I/O Options and Subcase Information Entry Used in the I/O Options section or in Acoustic Complex Eigenvalue Analysis Subcases to request displacement for acoustic grids. This output request is only supported for acoustic interface grids.
ACDISP (format, SUBSYS=SUBSYS_ID) = option
| Argument | Options | Description |
| format | <H3D, COUPLED, blank> Default = blank |
| SUBSYS | <SUBSYS_ID> No default |
ID of the subsystem. When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only. For more information, refer to the SET Bulk Data Entry. |
| option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When ACDISP command is not present, acoustic interface grid displacement is not output for acoustic complex eigenvalue subcases.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- When ACDISP is present in
an acoustic fluid-structure model, the following results are output.
- Displacement of fluid acoustic interface grids
- Displacement of structural acoustic interface grids
- Fluid Pressure results are also output
