ASSIGN
I/O Options and Subcase Information Entry Identifies external files and their contents.
For details regarding file specification information, refer to Comment 2.
ASSIGN, type, option1, option2, option 3
Examples
ASSIGN, PUNCH, C:\CMS\h3ddmig.pch
ASSIGN, H3DDMIG, AX, C:\CMS\h3ddmig.h3d
| Type | Option1 | Option2 | Option 3 | Description |
| AKUSMOD | filename | N/A | Identifies an external
file from which to read the AKUSMOD
fluid-structure coupling matrix. If this is not defined, it is presumed that the AKUSMOD coupling matrix is to be found in the same directory as the solver input file and is given the file name, ftn.70. Use of the AKUSMOD fluid-structure coupling matrix requires the presence of PARAM,AKUSMOD,YES. |
| DAC | TID | filename | Identifies an external
.dac file from which to read the load
history information for Fatigue Analysis. In addition to
ASSIGN,DAC entry the
TID value used here should match the
TID field of the FATLOAD
Bulk Data Entry for this load history to be used in the fatigue
solution.
Note: The LHFORMAT field of the
FATLOAD entry should be set to
DAC.
| EXCINP | SUBCASE ID | filename | Identifies an external
file from which to read the modal participation factors calculated
by AVL/EXCITE for both transient and FRF residual
runs, and GT-SUITE for transient runs. While running an AVL/EXCITE or GT-SUITE analysis, an .INP4 file is generated that contains the modal participation factors. The .INP4 file can be used along with the original flex H3D file to recover stresses, strains, displacements, velocities, and accelerations from a dynamic analysis run (only transient analysis for GT-SUITE). The SUBCASE ID is used to specify which SUBCASE the modal participation factors should be used for. Refer to Create Output for Third Party Software for more information. |
| EXTLOD | ID | .rsp/.rpc filename | .csv filename | Identifies an external
.rsp or .rpc file from
which external loads are for application in a transient analysis.
The ID defined on this ASSIGN entry can be
referenced on the EXCITEID field of a
TLOAD1 entry. The .csv file is used to identify the load mapping. |
| GETDISP | filename | N/A | Identifies an external
file from which the results of the selected subcases are recovered.
An actual file with the name Filename should
exist for GETDISP to work. This entry should be
added to the corresponding subcase(s) whose results are to be
restored. The solution process for the corresponding subcase will be
skipped. This entry can be added to more than one subcase, wherein,
the results for each such subcases will be restored from the
corresponding files. The set of grids in the restart file can only
be either the same as or a subset of the grids in the input deck.
Results for any grid which does not have corresponding data in the
restart file will be automatically set to zero. Note:
| H3DDMIG | matrixname | filename | This option can be used in
two ways, to identify external nodal flex .h3d
file to read DMIG matrices, or for identifying
flex body in residual run result recovery (in conjunction with modal
participation results from AVL/EXCITE and
GT-SUITE).
| H3DCDS | matrixname | filename | Identifies an external file from which to read complex dynamic matrices for a CDS residual run. Provides a prefix (matrixname) for the matrices contained therein and the path to and the name of the filename_CDS.h3d file. All of the matrices in the filename_CDS.h3d file are used in the analysis. | |
| H3DMBD | Flex Body ID | filename | This option can be used in
three ways, to identify flex body for result recovery or in further
OS-MBD analysis in the PFBODY Bulk Data Entry, or in fatigue analysis based on the recovered
stresses.
Refer to Create Output for Third Party Software and Recover MBD Analysis Results for more information. |
| H3DRES | ID | filename | Identifies an external
.h3d file for the following applications:
| HFILE | ID | filename | Identifies an external
file from which grid temperature at different time steps are
prescribed. Currently only PUNCH files are supported (SORT1 sorting method should be used while generating PUNCH files via THERMAL I/O Options Entry for compatibility with the HFILE option). This file is used for Nonlinear One-Step Transient Thermal Stress Analysis (NL-OSTTS) where temperature is applied as thermal load. The ID mentioned here is referenced on the HSI field of the TEMPT Bulk Data Entry. |
| INPUTT4 | filename.op4 | UNIT=ID (Fortran unit number of OP4 file) | N/A | This type is valid only
for partitioned/part superelements. Identifies an external OP4 file (filename.op4) from the DMIG matrices will be read. Unlike OP4DMIG option, an external .pch file need not be specified. The Fortran unit number specified here must match the definition in SEBULK (UNITNO field). Else this file will be ignored. |
| MATMDS | Material Name | Altair Multiscale Designer™ material model data filename. | Identifies an external material model file generated by Multiscale Designer. The “Material Name” of this ASSIGN entry can be referenced by the AMAT and AOPT fields of the MATMDS Bulk Data Entry. | |
| MBDINP | SUBCASE ID | filename | Identifies an external
by MotionSolve for Transient
Analysis. While running MotionSolve, an .mrf file is generated that contains the modal participation factors. The .mrf file can be used along with the original *.flexh3d file to recover stresses, strains, displacements, velocities, and accelerations during a Transient Analysis run. The SUBCASE ID is used to specify which SUBCASE the modal participation factors should be used for. Refer to Create Output for Third Party Software for more information. |
| MMO | Model Name | filename | Number of DDM mpi processes for each corresponding model (for DDM parallelization within MMO) | Identifies an external file to be included in a Multi-Model Optimization (MMO) run. "Model Name" is a user-defined label for the model, which can be used to qualify model-specific responses referenced on the DRESPM continuation lines of the DRESP2 and DRESP3 entries. The “Model Name” should be limited to 8 characters. |
| OP4DMIG | name | filename1.op4 | filename2.pch | This type is valid only
for standard/external superelements. Identifies an external OP4
file (filename1.op4) from which to read
DMIG matrices. Additionally, you can also specify a punch file
(filename2.pch) to read grids,
coordinate systems,
ASET/QSET/USET
and SPOINT data. All of the matrices in the
OP4 file are used in the analysis by default. If only some of
the matrices are to be used, then use the
K2GG, M2GG,
K42GG, and B2GG data
to specify which matrices are to be used. The unreferenced
matrices will not be used in this case.
Note: If a punch file is
not explicitly identified, then OptiStruct will use the punch file
that has the same name as the OP4 file.
| PUNCH | filename | N/A | Identifies an external file as the location to write DMIG data in PUNCH format. | |
| RPC | TID | filname | Identifies an external
.rpc file from which to read the load
history information for Fatigue Analysis. In addition to the
ASSIGN,RPC entry, the
solution.
RPC and the CHANNEL
field on FATLOAD should be
defined.
| SAVEDISP | filename | N/A | Identifies an external
file to which the analysis results of the selected subcase are
written. This entry should be added to the corresponding subcase(s)
whose results are to be saved. This entry can be added to more than
one subcase, wherein, the results for each such subcase will be
saved in a separate file. For optimization runs, the results during
the subsequent iteration will overwrite results of the preceding
iteration. Note:
| SIMPINP | SUBCASE | filename | Identifies an external
.unv file generated while running a
multibody dynamic analysis in SIMPACK. The
resulting CMS flexbody modal participation factors in the
.unv file can be used by OptiStruct to recover the dynamic
displacements, velocities, accelerations, stresses and
strains. The SUBCASE ID is used to specify which SUBCASE the modal participation factors should be used for. |
| UPDATE | filename | N/A | Identifies an external
file from which to read the updated cards after an optimization run.
The external file can have any file extension, as long as it is an
ASCII file that contains relevant
data. Currently, the following cards are supported: GRID MAT1, MAT2, MAT3, MAT4, MAT5, MAT8, MAT9, MAT10 PSHELL, PSOLID, PBAR, PBEAM, PELAS, PVISC, PDAMP, PBARL, PBEAML, PMASS, PROD, PBUSH, PBUSH1D, PAABSF, PWELD, PCOMPP, PSHEAR, PTUBE CTRIA3, CQUAD4, CTRIA6, CQUAD8 CONM2 CDAMP4, CELAS4 |
| MAP | ID | filename | Identifies an external
result file to be used for the thickness mapping feature. The ID used here must match ASID field of the MAP entry. For the external result file, LS-DYNA (.k) and Nastran formats (.nas) are supported. |
| MANUF | ID | filename | Identifies an external
result (.k) file to be used for stress
mapping. The ID used here must match the ASSIGN field of the INISTRS Bulk Data Entry. For the external result file, the .k file coming from LS-DYNA is supported. |
- ASSIGN, UPDATE is intended for optimization output. It allows you to modify physical values which may typically be changed during optimization. For example, GRID point locations, material parameters, and so on. However, it does not allow changes to the actual model setup (for example, material ID on the property entry, or coordinate system ID on the GRID entry cannot be changed).
- Multiple ASSIGN, UPDATE commands can be used to reference multiple files to be included in the model. However, data common to these multiple files will be overwritten. Exercise caution where multiple ASSIGN, UPDATE commands are specified. OptiStruct will print a WARNING message to the .out file, if data is overwritten.
- The MID field of the PSOLID entry can be updated using ASSIGN,UPDATE. All other fields, except FCTN, are skipped. Assigning improper material type may result in an error.
- The SEINTPNT Subcase Information Entry can only be used to convert interior super element grid points in .h3d files referenced by ASSIGN, H3DDMIG.
- File names used to identify files on the ASSIGN entry should be input as-is. That is, if the file being pointed to contains an extension, then the same extension should be used while specifying the file name on the ASSIGN entry. OptiStruct does not add or remove extensions and specified file names are used as-is. There is no requirement to use any extension at all, or a specific type of extension for any file. If the actual file does not have any extension, then it is also acceptable to input the file specification in the ASSIGN card without any extension.
