Bulk Data Entry Defines a free convection boundary condition for heat
transfer analysis through connection to a surface element (CHBDYE
card).
It can also used to define the ambient points for free convection, or for convection
with fluid flow via CAFLUID entry.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| CONV |
EID |
PCONID |
CNTRLND |
TA |
| Field |
Contents |
SI Unit Example |
| EID |
CHBDYE
surface element identification number. No default (Integer >
0)
| PCONID |
Convection property
identification number of a PCONV entry. No default
(Integer > 0)
| CNTRLND |
Control node for time
dependent convection coefficient. Default = 0 (Integer >
0)
| TAi |
TAi
fields can be used to define one of the following:
- Ambient points used to specify ambient temperature for free
convention; and/or,
- Specify points for convection with fluid flow belonging to
CAFLUID elements. Depending on the
location of the nodes belonging to the corresponding
CHBDYE entry, the proximal nodes of
the CAFLUID entry can be referenced on
the CONV entry to define the appropriate
setup for CAFLUID 1D fluid flow for heat
transfer.
No default (Integer > 0)
- The basic exchange relationship is expressed as:
(1)
Where,
- Free convection heat transfer coefficient specified on a MAT4 entry, referred by a
PCONV entry
- Time-dependent multiplier provided by SPCD,
which constrains node identified by CNTRLND
field
- Grid temperature
- Ambient temperature
- The time-dependent multiplier (
) for the heat transfer convection coefficient is
controlled via control nodes (CNTRLND field). The same nodes
should be referenced on SPCD entries. Time-dependency is
activated by referencing the corresponding SPCD entry on
TLOAD1/TLOAD2 entries.
- CONV is used with a
CHBDYE entry having the same EID.
- In linear steady-state heat transfer
analysis, ambient temperature is specified by SPC of the
TA point.
- This card is represented as a secondary
element in HyperMesh.
