DMGINI
Bulk Data Entry Defines the damage initiation criteria.
| DMGINI | DMGINIID | CRI | FLAT | LODE | |||||
| Y1 | X1_1 | X1_2 | X1_3 | ||||||
| Y2 | X2_1 | X2_2 | X3_3 | ||||||
| Y3 | X3_1 | X3_2 | X3_3 | ||||||
| etc. | etc. | etc. | etc. |
Example 1
| DMGINI | 20 | MAXS | |||||||
| 20.0 | 50.0 | 50.0 |
Example 2
| DMGINI | 22 | QUADE | |||||||
| 2.0E-3 | 2.4E-3 | 2.4E-3 |
Example 3
| DMGINI | 22 | DUCTILE | |||||||
| 0.03 |
Example 4
| DMGINI | 22 | DUCTILE | FLAT | ||||||
| 1.5 | -0.33 | 0.0 | |||||||
| 0.25 | 0.0 | 0.0 | |||||||
| 0.12 | 0.667 | 0.0 | |||||||
| 0.75 | -0.33 | 1000.0 | |||||||
| 0.125 | 0.0 | 1000.0 | |||||||
| 0.06 | 0.667 | 1000.0 |
Example 5 (Ductile damage initiation with LODE)
| DMGINI | 22 | DUCTILE | FLAT | LODE | |||||
| 1.5 | -0.33 | -1.0 | 0.0 | ||||||
| 0.25 | 0.0 | -1.0 | 0.0 | ||||||
| 0.12 | 0.667 | -1.0 | 0.0 | ||||||
| 0.75 | -0.33 | 1.0 | 0.0 | ||||||
| 0.125 | 0.0 | 1.0 | 0.0 | ||||||
| 0.06 | 0.667 | 1.0 | 0.0 | ||||||
| 1.5 | -0.33 | -1.0 | 1000.0 | ||||||
| 0.25 | 0.0 | -1.0 | 1000.0 | ||||||
| 0.12 | 0.667 | -1.0 | 1000.0 | ||||||
| 0.75 | -0.33 | 1.0 | 1000.0 | ||||||
| 0.125 | 0.0 | 1.0 | 1000.0 | ||||||
| 0.06 | 0.667 | 1.0 | 1000.0 |
| DMGINIID | Damage initiation
| CRI | Damage initiation criteria.
No default (Real) |
| LODE | Valid only for
CRI=DUCTILE. Flag to activate load parameter dependence for ductile damage initiation. Default = blank |
| FLAT | Valid only for
CRI=DUCTILE. Specifies the handling method for y-values outside the specified range of x-values.
| Y_#, X#_i, X#_j, X#_k | The maximum value of
strain or stress/traction depending on damage initiation
type. No default (Real > 0.0) |
for
MAXE/QUADE/DUCTILE criteria for MAXS/QUADS criteria |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
- Support information for the damage
initiation criteria are:
Analysis Types Criterion Nonlinear Static Analysis, Nonlinear Transient Analysis MAXE, MAXS, QUADE, QUADS, DUCTILE Explicit Dynamic Analysis DUCTILE Element Types Criterion Regular Shell and Solid Elements MAXE, MAXS, QUADE, QUADS, DUCTILE Cohesive Elements MAXE, MAXS, QUADE, QUADS - When the DUCTILE
damage initiation criterion is used, the parameters are used:
LODE flag Y_# X#_i X#_j X#_k Specified Plastic Strain at failure Stress triaxiality Lode parameter Strain rate Blank Plastic Strain at failure Stress triaxiality Strain rate - For additional information about cohesive elements, refer to Cohesive Zone Modeling in the User Guide.
