FAILURE
I/O Options and Subcase Information Entry Used to request failure output for elements referencing PSOLID or PSHELL properties for all subcases or individual subcases, respectively.
FAILURE (format_list, location, SUBSYS=SUBSYS_ID) = option
| Argument | Options | Description |
| format | <H3D, blank> |
| location | <CORNER, blank> |
| SUBSYS | <SUBSYS_ID> No default |
ID of the subsystem. When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only. For more information, refer to the SET Bulk Data Entry. |
| option | <YES, NO, blank> |
- Multiple formats are allowed on the same entry, these should be comma separated. If no format is specified, then this output control applies to all formats defined by OUTPUT or FORMAT commands, for which the result is available.
- For more information on the supported analysis types and formats, refer to Results Output by OptiStruct.
- The von Mises, Tresca, Major Principal, and Minor Principal Factor of Safety (FOS), and the corresponding Margin of Safety (MOS) results are printed to the H3D file. The allowable stress fields, SC, ST, or SS on the referenced materials (MAT1 or MATT1) should be defined to output all failure criteria.
