JOINTD
I/O Options EntryOutput request. The JOINTD command can be used in the I/O Options section to request output of JOINTG Displacement.
JOINTD (format) = option
| Argument | Options | Description |
| format | <H3D, OPTI> Default = H3D |
| option | <YES, ALL,
NO> Default = ALL |
- JOINTD output is only available in the .h3d, _impl.h3d, _expl.h3d and .joint file. It is currently supported for all solutions for which JOINTG elements are supported.
- JOINTD output consists of JOINTG Displacement results.
- JOINTD results are not output by default for any analysis type; if JOINTG displacement results are expected, the JOINTD entry should be specified in the model.
- JOINTD output is
printed in its own separate label in the H3D file:
JOINTG Displacement (1D) (s).
