JOINTF
I/O Options EntryOutput request. The JOINTF command can be used in the I/O Options section to request output of JOINTG Forces.
JOINTF (format) = option
| Argument | Options | Description |
| format | <H3D, OPTI> Default = H3D |
| option | <YES, ALL,
NO> Default = ALL |
- JOINTF output is only available in the .h3d, _impl.h3d, _expl.h3d and .joint file. It is currently supported for all solutions for which JOINTG elements are supported.
- JOINTF output
consists of the following results:
- JOINTG Forces
- JOINTG Reaction Forces
- JOINTG Viscous Forces (available if PROPERTY on PJOINTG is DAMP)
- JOINTG Stop and Lock Status
- JOINTF is set to YES by default for linear static and nonlinear static analyses.
- JOINTF outputs are printed in their own separate labels in the H3D file, such as JOINTG Forces (1D) (s), JOINTG Reaction Forces (s), and so on.
