Bulk Data Entry Defines a linear combination of mass cases to form the subcase dependent mass.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MASSSET |
ID |
SA |
S0 |
ID0 |
S1 |
ID1 |
S2 |
ID2 |
S3 |
ID3 |
etc. |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MASSSET |
10 |
1.0 |
1.0 |
0 |
1.0 |
10 |
| Field |
Contents |
SI Unit Example |
| ID |
Identification number referenced by MASSSET
Subcase Information Entry. No default (Integer > 0)
| SA |
The overall scale factor for the linear combination. Default =
0.0 (Real)
| Si |
The scale factor for the linear combination. Default = 0.0
(Real)
| IDi |
The MASSID for the i'th mass section. This is
the ID defined on the SEID field of the
BEGIN,MASSID entry to
identify the corresponding mass section. No default (Integer >
0)
- This entry is referenced by the MASSSET Subcase
Information Entry.
- Fixed reference frame method is adopted for 3D rotor dynamic
analysis.
- The mass of a section is calculated as:(1)
Where,
- Mass of the linear combination of mass cases.
- Overall scale factor of the linear combination.
- Scale factor of the i'th mass section.
- Mass of the i'th mass section identified by the
IDi field. It is the mass of the mass
section defined on the corresponding
BEGIN,MASSID
entry.
- ID of the MASSID section; i = 0 is the base
mass case.
- IDs for mass sections defined on the MASSSET Bulk
Data Entry should be unique.
