MAT3
Bulk Data Entry Defines the material properties for linear, temperature-independent, and orthotropic materials used by the CTAXI, CTRIAX6, CQAXI, CTAXIG, and CQAXIG axisymmetric elements, and CTPSTN and CQPSTN plane strain elements.
| MAT3 | MID | EX | ETH | EZ | NUXTH | NUTHZ | NUZX | RHO | |
| GXTH | GTHZ | GZX | AX | ATH | AZ | TREF | GE |
| MAT3 | 17 | 3.0+7 | 3.1+7 | 3.2+7 | 0.33 | 0.28 | 0.30 | 2.0e-5 | |
| 6.5+6 | 6.8+6 | 7.0+6 | 1.1e-4 | 1.1e-4 | 1.2e-4 | 35.5 | 0.19 |
| MID | Unique material identification.
No default (Integer > 0 or <String>) |
| EX, ETH, EZ | Young's moduli in the x,
out-of-plane, and z directions, respectively. No default (Real > 0.0) |
| NUXTH, NUTHZ, NUZX | Poisson's ratios.
No default (Real) |
| RHO | Mass density. No default (Real) |
| GZX | Shear modulus in the x-z
plane. No default (Real > 0.0) |
| GTHZ, GXTH | Shear moduli that are only
effective for general axisymmetric elements
CTAXIG and
CQAXIG.GTHZ is the shear
modulus in the theta-z plane. GXTH is the shear
modulus in the x-theta plane. Default = GZX (Real > 0.0 or blank) |
| AX, ATH, AZ | Thermal expansion
coefficient in the x, out-of-plane, and z directions,
respectively. No default (Real) |
| TREF | Reference temperature for
thermal loading. Default = blank (Real or blank) |
| GE | Structural element damping
coefficient. 8 No default (Real) |
- The indices of ‘z’ or ‘Z’ above represent (a) the in-plane z direction if the analysis is defined in x-z plane, or (b) the in-plane y direction if the analysis is defined in x-y plane. The out-of-plane index, ‘TH’ represents (a) the hoop direction in axisymmetric analysis, or (b) the direction of thickness in plane strain analyses, see Comment 7.
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
- String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- Values of seven elastic constants, EX, ETH, EZ, NUXTH, NUTHZ, NUZX and GZX must be present. GTHZ and GXTH are only effective for genearl axisymmetric elements CTAXIG and CQAXIG.
- A warning is issued if absolute value of NUXTH or NUTHZ is greater than 1.0.
- The x, out-of-plane and z directions are principal material directions of the material coordinate system. The elements supported by MAT3 contains a THETA field to relate the principal material directions to the basic coordinate system.
- The strain-stress relations are defined
as:
- 2D axisymmetry
(1) with and .
- general axisymmetry
(2) with and
- plain strain analysis
(3) with .
The material constants associated with ‘TH’ (that is, , , and ) are used to calculate the out-of-plane stress in plane strain analysis.(4) Note: The strain and stress here are both defined in the material coordinate system. - 2D axisymmetry
- To obtain the damping coefficient GE, multiply the critical damping ratio, by 2.0.
- This card is represented as a material in HyperMesh.
