MODCHG
Subcase Information Entry The MODCHG command can be used to remove and/or reactivate contact interfaces and/or elements for this subcase. It is used only for nonlinear analysis.
MODCHG = option
| Argument | Options | Description |
| option | <SID> No default |
- MODCHG Bulk Data Entries will not be used unless selected in the Subcase Information section.
- For a fresh nonlinear analysis subcase (without any
CNTNLSUB or with CNTNLSUB prescribed
to be NO), a contact interface and a set of elements can be
active or inactive depending on whether and how they are referenced by
MODCHG.
- Contact and/or Elements
- Active/Inactive
- Removed with MODCHG
- Inactive
- Added with MODCHG
- Active
- Others
- Active
- For a subsequent nonlinear analysis subcase (with
CNTNLSUB prescribed to be YES or a
subcase ID), a contact interface and a set of elements can be active or inactive
depending on whether and how they are referenced by MODCHG
and whether they are active or not in the preceding subcase.
- Active/Inactive
- Inactive
- Added with MODCHG
- Active
- Others
- Active, if active in the preceding subcase
