PAXIG
Bulk Data Entry Defines the properties of general axisymmetric elements. References by the CTAXIG and CQAXIG elements.
| PAXIG | PID | MID | CID | AXIS |
| PAXIG | 2 | 203 | 81 | 2 |
| PID | Unique general
axisymmetric element property identification number. No default (Integer > 0) |
| MID | Identification number of a
MAT1 or MAT3
entry. No default (Integer > 0) |
| CID | Identification numbers to
edge grid points.
| AXIS | Defines the axis of the
coordinate system specified by the CID field the
axis of symmetry.
- All general axisymmetric element property entries must have unique ID numbers.
