PFATSDR
Bulk Data Entry Defines properties for solder fatigue analysis.
| PFATSDR | ID | C4GAMMA | K1 | K2 | K3 | K4 |
Definition
| ID | Entry identification
number. Each PFATSDR entry must have a unique ID. This is referenced by the FATDEF Subcase Information Entry. No default (Integer > 0) |
| C4GAMMA | Empirical model constraint
for solder fatigue. No default (Real > 0) |
| K1 | Constant in crack
initiation equation in Darveaux method. 2 No default (Real) |
| K2 | Constant in crack
initiation equation in Darveaux method. No default (Real) |
| K3 | Constant in crack growth
| K4 | Constant in crack growth
- C4GAMMA is used to calculate the strain range of the
solder joint in DIFFCTE method:
(1) Where,- Component length.
- Coefficient of thermal expansion (CTE).
- Solder joint height.
- Difference between thermal expansion coefficients of the PCB and the component soldered onto the board.
- Input temperature.
- Difference between temperatures of the PCB and the component soldered onto the board.
- Empirical model constant for solder fatigue (specified using the C4GAMMA field). It is equal to for leadless joint type. For BGA type, you can define the empirical model constant.
Refer to Solder Fatigue Analysis for additional information.
- K1 and
K3 are dependent on the modeling of solder joints such as
the thickness of solder joint interface layers and the creep constitutive model.
Therefore, K1 and K3 are not material
constants. Units of dimension for K1 and
K3 should be consistent with those of length and stress
on FATPARM. Dimension of K1 is
cycles/stressK2. The dimension of K3 is
(length/cycle)*(1/stressK4). For example, if length units and
stress units in FATPARM are mm and MPa respectively, the
units of K1 and K3 should be cycles/MPaK2 and
(mm/cycle)*(1/MPaK4), respectively.The constants are used in the following equations to calculate life (N) of a solder joint:
- Crack initiation:
(2) - Crack growth:
(3) - Life:
(4)
Where, is the joint diameter at the interface defined FATSDR.
- Crack initiation:
