STEADY
Subcase Information Entry The STEADY command can be used in the subcase information section to activate steady state analysis. It identifies a STEADY Bulk Data Entry that contains information required to activate steady state analysis.
STEADY = option
STEADY = 3
| Argument | Options | Description |
| option | <STID> |
- Steady state analysis is used to convert results of an FRF analysis from frequency domain to time domain and combine the results with a linear static subcase and another FRF subcase in time domain.
- The IMPORT I/O Options Entry can be used in the corresponding FRF and linear static subcase to run steady state analysis directly from H3D files. All the corresponding subcases should contain the IMPORT I/O Options Entry in such a situation.
