The following approaches are available to handle stress constraints for Topology and
Free-size Optimization.
Note: Augmented Lagrange Method is only supported for Topology Optimization.
Norm-based Approach (Topology and Free-size Optimization)
The Norm-based approach
is the default method for handling stress responses for Topology and Free-Size
Optimization. This method is used when corresponding stress response
RTYPE’s on the DRESP1 Bulk Data
Entry are input.
The Response-NORM
aggregation is internally used to calculate the stress responses for groups of
elements in the model. Solid, shell, bar stresses and solid corner stresses are
supported with the Response-Norm aggregation approach (Free-size Optimization is
only supported for shell stresses). Refer to NORM Method for more information.
Augmented Lagrange Method (ALM) (Topology Optimization only)
The Augmented Lagrange
Method (ALM) is an alternative method for handling stress responses for Topology
Optimization. It can be activated using DOPTPRM,ALMTOSTR,1 when DRESP1 Bulk Data Entry is
used to specify local stress responses.
ALM is also an
alternative method to efficiently solve topology optimization problems with local
stress constraints, which is stated in Equation 1.
(1)
Where,
- Vector of topology design variables
- Objective function
- jth constraint
- Number of local stress constraints
- Total number of constraints
Typically,
is equivalent to the number of elements and is a
large number. ALM converts the optimization
Equation 1 to the following format:
(2)
(3)EQ 2
Where,
- Element density
- Element von Mises stress
- stress upper bound
- Lagrange multiplier estimator
- Quadratic penalty factor
- The penalty factor is typically updated as:(4)
- Where,
- Update parameter
- Upper limit to prevent numerical instabilities
The Lagrange multiplier
estimators are updated as
In general, the number of
is very large. Directly solving Equation 1 is computationally time consuming. By
penalizing the stress constraints onto the objective function, the total number of
constraints can be significantly reduced. As a result, the optimization problem can
be efficiently solved.
The parameters are set as
is initially set to 1.0 and multiplied by 1.3 in every five iterations, with an
upper limit of 30.0. Based on this process, Topology Optimization is carried out
within one phase.
Note: Except for this ALM, OptiStruct
generally uses a multi-phase strategy to solve topology optimization
problems.
The default Stress-norm
(P-norm) method continues to efficiently solve Topology Optimization problems with
local stress constraints. The ALM 1 is a good alternative for such models.
Global von Mises Stress Response (Topology and Free-size Optimization)
The von Mises stress
constraints may be defined for topology and free-size optimization through the
STRESS optional continuation line on the
DTPL or the
DSIZE card. There are a number
of restrictions with this constraint:
- The definition
of stress constraints is limited to a single von Mises permissible stress.
The phenomenon of singular topology is pronounced when different materials
with different permissible stresses exist in a structure. Singular topology
refers to the problem associated with the conditional nature of stress
constraints, that is, the stress constraint of an element disappears when
the element vanishes. This creates another problem in that a huge number of
reduced problems exist with solutions that cannot usually be found by a
gradient-based optimizer in the full design space.
- Stress
constraints for a partial domain of the structure are not allowed because
they often create an ill-posed optimization problem since elimination of the
partial domain would remove all stress constraints. Consequently, the stress
constraint applies to the entire model when active, including both design
and non-design regions, and stress constraint settings must be identical for
all DSIZE and DTPL cards.
- The capability
has built-in intelligence to filter out artificial stress concentrations
around point loads and point boundary conditions. Stress concentrations due
to boundary geometry are also filtered to some extent as they can be
improved more effectively with local shape optimization.
- Due to the
large number of elements with active stress constraints, no element stress
report is given in the table of retained constraints in the
.out file. The iterative history of the stress
state of the model can be viewed in HyperView or
HyperMesh.
- Stress
constraints do not apply to 1D elements.
- Stress
constraints may not be used when enforced displacements are present in the
model.
The buckling factor can
be constrained for shell topology optimization problems with a base thickness not
equal to zero. Constraints on the buckling factor are not allowed in any other cases
of topology optimization.
The following responses
are currently available as the objective or as constraint functions for elements
that do not form part of the design space:
| Composite Stress |
Composite Strain |
Composite Failure
Criterion |
| Frequency Response
Stress |
Frequency Response
Strain |
Frequency Response Force |
