/ARCH (Obsolete)
Block Format Keyword Describes the architecture flag.
| /ARCH | |||||||||
| Mach1 | Mach2 | Mach3 | Mach4 | Mach5 | Mach6 | Mach7 | Mach8 | ||
Definition
| Mach1 | Optimization and
platform flag.
(Integer) |
| Mach2,..., Mach8 | Architecture compatibility flag.
(Integer) |
Radioss Platform Number
- Platform ID Number
- Platform Name
- 2
- CRAY T90, T90-IEEE
- 3
- SGI65
- 4
- HP11 PA-RISC
- 5
- IBM Power 4
- 6
- HP Alpha
- 7
- Fujitsu VPP 5000
- 8
- NEC SX6
- 9
- Linux IA32
- 10
- Linux IA64
- 11
- HP11 IA64
- 12
- Linux X86-64
- 13
- Fujitsu Primepower
- 14
- CRAY X1
- 15
- Sun Sparc
- 16
- Windows IA32
- 17
- Linux Alpha
- It is required that the parallelism type
be identical between Starter and Engine (for example, SPMD Starter and SPMD Engine
executables).
Above is a list of the actual platforms. New platforms will be added when available.
- For performance point of view, it is recommended to set only one platform, which corresponds to the Radioss Engine machine. Using generic platform or setting more than one platform may decreases performance of Radioss Engine.
