*CONSTRAINED_NODAL_SET
LS-DYNA Input Interface KeywordDefines a translational constraint to a set of nodes in the global coordinate system. There is no rotational coupling.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_NODAL_SET_{OPTION} | |||||||
| rlink_ID |
| NSID | DOF |
Definition
| OPTION |
| rlink_ID | Nodal constraint
identifier. (Integer) |
| NSID | Nodal set
| DOF | If DOF =
1, then direction of displacement
constraint.
(Integer) |
- This keyword maps to /RLINK.
