*CONTACT_TIEBREAK
LS-DYNA Input Interface KeywordDefines tied contact between entities without failure.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTACT_TIEBREAK_{OPTION2}_{OPTION3} | |||||||
| inter_ID | Title | ||||||
| SSID | MSID | SSTYP | MSTYP | ||||
| Blank line | |||||||
| SST | MST | SFST | SFMT | ||||
Definition
| OPTION2 |
| OPTION3 |
| inter_ID | Contact ID. (Integer) |
| Title | Contact title (when
OPTION3=ID is
defined). (Character) |
| SSID | Secondary nodal
set. (Integer) |
| MSID | Main surface
set. (Integer) |
| SSTYP | Input secondary set type:
(Integer) |
| MSTYP | Input main set type:
(Integer) |
| SST | Secondary maximum gap
value. (Real) |
| MST | Main maximum gap
value. (Real) |
| SFTS | Secondary contact gap
scale. (Real) |
| SFMT | Main contact gap
scale. (Real) |
- This keyword maps to /INTER/TYPE2 with Spotflag = 28.
- Failure behavior is not taken into account.
