*DATABASE_HISTORY_NODE
LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DATABASE_HISTORY_NODE_{OPTION} | |||||||
| ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ID8 |
| Etc. | |||||||
If OPTION = LOCAL, insert the following lines.
| ID1 | CID | REF | |||||
| ID2 | CID | REF | |||||
| Etc. |
Definition
| OPTION |
| ID | Node identifier. (Integer) |
| CID | Local coordinate system identifier used for
output. (Integer) |
| REF |
(Integer) |
- This keyword maps to /TH/NODE.
- A moving coordinate system based on nodes is used when REF=1.
