/ENCRYPT
Block Format Keyword Keyword encryption for input options.
| /ENCRYPT/keyid | |||||||||
| Header string1 | |||||||||
| [keyid] Header string2 | |||||||||
| [keyid] Header string3 | |||||||||
| [keyid] Header string4 | |||||||||
| [keyid] Header string5 | |||||||||
Definition
| keyid | Encryption key ID | |
| Header string1 | Encryption string
1 (Character maximum 100 characters) |
| [keyid] Header string2 | Encryption string
2 (Character maximum 100 characters) |
| [keyid] Header string3 | Encryption string
3 (Character maximum 100 characters) |
| [keyid] Header string4 | Encryption string
4 (Character maximum 100 characters) |
| [keyid] Header string5 | Encryption string
5 (Character maximum 100 characters) |
- Altair HyperWorks FEA pre-processors must be used to generate the encryption keyid and strings.
- keyid uses the
format %AB123.
Where, AB= any 2 letters and 123=any 3 numbers, such as %TY583.
- The keyid is repeated at the beginning of header strings 2 – 5.
- /ENCRYPT and /KEY cannot use the same keyid in the same model.
- The following entities can be
encrypted in the model:
- Any material (/MAT/...)
- Any failure model (/FAIL/...)
- Any viscous model (/VISC/...)
- Any equation of state (/EOS/...)
- Any property (/PROP/...)
- Functions /FUNCT and /FUNCT_SMOOTH
