/EOS/IDEAL-GAS-VT
Block Format Keyword Describes the equation of state for ideal gas (volume - temperature).
Describes the equation of state for ideal gas ; where, is temperature dependent and described with Janaf model: (SI: )
| /EOS/IDEAL-GAS-VT/mat_ID/unit_ID | |||||||||
| eos_title | |||||||||
| T0 | P0 | Psh | |||||||
| A0 | A1 | A2 | A3 | A4 | |||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| eos_title | EOS title. (Character, maximum 100 characters) |
| Ideal gas
constant. (Real) |
| T0 | Initial temperature. If
P0 not defined, refer to Comment 3. (Real) |
| P0 | Initial pressure. If T0 is not defined, refer to Comment 3. (Real) |
| Psh | Pressure
shift. (Real) |
| A0 | Specific heat capacity
parameter. (Real) |
| A1 | Specific heat capacity
parameter. (Real) |
| A2 | Specific heat capacity
parameter. (Real) |
| A3 | Specific heat capacity
parameter. (Real) |
| A4 | Specific heat capacity
parameter. (Real) |
Example (Air)
/UNIT/1
unit for mat
g mm ms
/MAT/LAW6/1/1
Air
# RHO_I
1.22e-6
/EOS/IDEAL-GAS-VT/1/1
Air
# r T0 P0 PSH
287 0 0.1 0
# A0 A1 A2 A3 A4
1004.5 0 0 0 0
#enddata
- Ideal gas EOS is
Where,
- Volume
- Universal ideal gas constant (SI: )
- Temperature
It can also be written or .
Where,- Specific volume ( )
- Gas constant (SI: ), ; where, is molecular mass
- Alternative form of
ideal gas is /EOS/IDEAL-GAS-VE (Volume
Energy):
(1) Where,- Is constant
Consequently, when is constant, defining , and will provide the same equation of state as /EOS/IDEAL-GAS-VE formulation.
- If T0 is defined, then P0 is
computed:
(2) Otherwise, if P0 is defined, then T0 is computed:(3) - The
function is provided with Janaf
model:
(4) (SI: )
- Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
