/FAIL/MAXSTRAIN
Block Format Keyword Maximum strain failure criterion for modeling the failure of composite materials. This criterion is available for solids and shells.
/FAIL/MAXSTRAIN/mat_ID/unit_ID | |||||||||
Ifail_sh | Ifail_so | ||||||||
Fcut |
fail_ID |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | (Optional) Unit
Longitudinal critical
strain. Default = 1020 (Real) |
Transverse critical
Shear critical engineering
Ifail_sh | Shell failure model flag.
(Integer) |
Ifail_so | Solid failure model flag.
(Integer) |
Dynamic time relaxation. 5 Default = 1020 (Real) |
Fcut | Stress tensor filtering
frequency. Default = 0.0 (Real) |
fail_ID | (Optional) Failure criteria
identifier.4
/UNIT/1
Mg mm s
/FAIL/MAXSTRN/1/1
# EPS1_MAX EPS2_MAX GAM12_MAX IFAIL_SH IFAIL_SO
0.052 0.045 0.0157 1 1
# TAU_MAX FCUT
1.0E-4 100.0ZZ
- This failure model is available for shells and solids. It considers
a composite ply with the fibers oriented in the direction 1 (also denoted as
m1) and the matrix oriented in transverse direction 2 (and 3 for solids).
Each direction considers a critical strength value valid for both tension
and compression:
Figure 1.Where, , , are respectively the critical strain in direction 1, critical strain in direction 2 and critical engineering strain in shear.Note:Where, is the shear strain.
- The failure criterion for shells is written as:
(1) For solids the criterion becomes:(2) The criterion is considered to be reached when . The damage variable corresponds to the criterion itself .
- Once the criterion is
reached
, two behaviors can be set up:
- If Ifail_sh = 0 or Ifail_so = 0, there is no stress softening and elements are never deleted. In this case, the failure criterion is purely visual using the output of the damage variable.
- If Ifail_sh ≠
0 or
Ifail_so ≠
0, a stress relaxation is generated to decrease
the load carrying capacity of the element.
(3) With and .
Where,- Time.
- Start time of relaxation when the damage criteria is assumed.
- Time of dynamic relaxation.
- Stress tensor when the criterion is reached.
When the stresses reach 1% of the stress value at the beginning of the failure, the element is deleted. This is necessary to avoid instabilities coming from a sudden deletion of an element and a failure “chain reaction” in the neighboring elements. Even if the failure criterion is reached, there will be no element deletion with the default value of . Therefore, it is recommended to define a value for 10 times larger than the simulation time step.
- To avoid “chain
reaction” when deleting elements, you can also define a stress tensor
filtering frequency Fcut. Thus, the stress tensor used to calculate the MAXSTRAIN criterion is
first to be filtered according to:
(4) With
Where, is the current timestep.
If a filtering frequency is not defined (Fcut= 0.0), the filtering effect is deactivated.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
