Block Format Keyword Describes the stress softening mullins effect that is observed during a cyclic loading
unloading based on the criterion proposed by Ogden and Roxburgh.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| /FAIL/MULLINS_OR/mat_ID/unit_ID |
| R |
m |
Optional line
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| fail_ID |
Definition
| Field |
Contents |
SI Unit Example |
| mat_ID |
Material identifier. (Integer, maximum 10
digits)
| unit_ID |
Optional unit identifier. (Integer, maximum 10
digits)
| R |
Damage parameter relative to undeformed material. 1
3 Default = 1.0
(Real)
Damage parameter. 1
3 (Real)
| m |
Damage parameter relative to deformation. 1
3 (Real)
#RADIOSS STARTER
/UNIT/1
unit for material and failure
Mg mm s
/MAT/LAW100/1/1
Neo Hookean material
1.000000000000E-09
#N_NETWORK FLAG_HE FLAG_CR
0 3
# C10 D1
0.5000
/FAIL/MULLINS_OR/1/1
# R BETA m
2.0 0.02 0.2
#ENDDATA
- This failure model can
only be used with materials /MAT/LAW92,
/MAT/LAW95, and /MAT/LAW100.
- The stress during the
first loading process is equal to the undamaged stress. Upon unloading and
reloading the stress is multiplied by a positive softening factor
function:(1)
Where,
- The deviatoric part of the stress.
- Hydrostatic pressure.
- Damage factor that is a function of the strain energy of the
hyperelastic model which respects:
(2)
Where,
is the maximum strain energy that the
material has been subjected to during its loading
history:
(3)
Where,
is the Gauss error function.
- The larger the
parameter
, the less
can depart from unity and hence less damage can
occur. For small values of m, there is more damage at
smaller strains. For higher values of m, there is less
damage in the small strain region during the initial loading, but during
reloading there is will be more damage at smaller strains. Smaller values of
result in increased damage.
- There is no failure or
element deletion with this failure model.
