/FAIL/XFEM_TBUTC (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
| /FAIL/XFEM_TBUTC/mat_ID/unit_ID | |||||||||
| K | r | Ifail_sh | Iduct | ||||||
| a | b | ||||||||
Optional Line
| fail_ID | |||||||||
Definition
| mat_ID | Material
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| Exponent (Real) |
| K | Critical damage
integral Default = 1030 (Real) |
| r | Fracture stress Default = 1030 (Real) |
| Ifail_sh | Shell failure flag
(Integer) |
| Iduct | Ductile-brittle materials flag
(Integer) |
| a | Material parameter
(exponent) (Real) |
| b | Material parameter
(exponent) (Real) |
| fail_ID | (Optional) Failure
criteria identifier 5 (Integer, maximum 10 digits) |
- This failure model is available for Shell only.
- An element fails once
the Tuler-Butcher cumulative damage parameter is greater than the stated critical
damage value, K. The damage parameter accumulation is calculated
differently for ductile and brittle materials
(Iduct = 1
or 2).For ductile materials, the cumulative damage parameter is:
(1) Where,- r
- Fracture stress
- Maximum principal stress
- Material constant
- t
- Time when shell cracks for initiation of a new crack within the structure
- D
- Damage integral, another material constant
- For brittle
materials, the damage parameter is:
(2) (3) (4) - Current known
limitations are:
- /PARITH/ON does not ensure results repeatability, if SPMD > 1; it works in SMP parallel mode only.
- XFEM is currently NOT compatible with either /ANIM/VECT or with /PARITH/OFF.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
