/FRAME/FIX
Block Format Keyword Describes the frames.
/FRAME/FIX/frame_ID/unit_ID
frame_title
Ox Oy Oz
X1 Y1 Z1
X2 Y2 Z2
Definition
frame_ID Reference frame identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier
frame_title Reference frame title
Ox X coordinate of frame origin O'
(Real)
[ m ]
Oy Y coordinate of frame origin O'
(Real)
[ m ]
Oz Z coordinate of frame origin O'
(Real)
[ m ]
X1 X component of frame axis Y '
(Real)
Y1 Y component of frame axis Y '
(Real)
Z1 Z component of frame axis Y '
(Real)
X2 X component of axis Z ' '
(Real)
Y2 Y component of axis Z '
(Real)
Z2 Z component of axis Z '
(Real)
  1. The reference frame identifier must be different from all skew identifiers.
  2. The reference frame is fixed and its directions are defined by Y ' and Z ' . Vectors of arbitrary length may be given.
  3. Input is Y ' axis and Z ' axis, but X' axis is computed as:(1)
    X ′ = Y ' Λ Z '
    Y ' is recomputed as: (2)
    Y ″ = Z ′ Λ X ′
    Therefore, the new reference frame is defined by X ′ , Y ″ ', and Z ' .
    fixed_ref_frame
