View new features for Radioss 2023.
Current Radioss format uses the 12x extension format.
Block Format Keyword
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Keywords used to set the default value.
Block Format Keyword In this group, keywords are used to set Rayleigh mass and stiffness damping coefficients, which apply to a set of nodes used to stabilize the results.
Block Format Keyword Describes the treatment of element closure.
Block Format Keyword This card enables grid formulation for ALE modeling. The ALE domain can have moving boundaries.
Block Format Keyword This option allows for a second order MUSCL (Monotonic Upstream-Centered Scheme for Conservation Laws) reconstruction of volumic fraction fields when using Multi-Material laws (LAW51), and for a full second order scheme (time and space) when using material LAW151.
Block Format Keyword This option defines the numerical method for internal force integration. This is relevant only for brick element and ALE legacy solver (momentum equation solved with FEM).
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
