/INIBRI/EREF
Block Format Keyword Describes the initial reference state for solid element using global strain formulation.
| /INIBRI/EREF/unit_ID | |||||||||
| brick_ID | Isolnod | Isolid | Ismstr | Nsrot | |||||
| Xc | Yc | Zc | |||||||
| Rx | Ry | Rz | |||||||
Definition
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| brick_ID | Element
identifier. (Integer) |
| Isolnod | Number of nodes of solid
element. (Integer) |
| Isolid | Solid element
formulation. Corresponding to the solid formulation of the property definition of this element. (Integer) |
| Ismstr | Small strain formulation
flag. Corresponding to the small strain formulation of the property definition of this element. (Integer) |
| Nsrot | Number of nodes with
rotational degree of freedom. (Integer) |
| Xc | X coordinate in the global
coordinate system relative to the last node coordinate of the solid
element. (Real) |
| Yc | Y coordinate in the global
element. (Real) |
| Zc | Z coordinate in the global
element. (Real) |
| Rx | Historic X rotation in the
global coordinate. (Real) |
| Ry | Historic Y rotation in the
| Rz | Historic Z rotation in the
- The initial state for brick may be defined by more than one block.
- The reference state nodal coordinate must be written in the same order from 1 to Isolnod as it is defined in the solid element card.
- The coordinate of the last node of the solid element is 0, 0, 0. The coordinates of the other nodes of the element are defined relative to this node.
- Nsrot=4 has been used for the case of Itetra4=1, where the rotational dofs are used for fictive middle node kinematic compute.
