/INTER/LAGMUL/TYPE16
Block Format Keyword This interface simulates impact between nodes and external surfaces of brick. The external surfaces can be 16-node thick shell element, 20-node brick element, 8-node brick or 8-node thick shell element.
This interface uses Lagrange Multiplier kinematical conditions. These kinematical conditions are only compatible with other Lagrange Multipliers kinematical conditions. This interface formulation is not compatible with SPMD parallel version.
| /INTER/LAGMUL/TYPE16/inter_ID/unit_ID | |||||||||
| inter_title | |||||||||
| grnd_IDs | grbrc_IDm | ||||||||
| ITIED | |||||||||
Definition
| inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| inter_title | Interface
title. (Character, maximum 100 characters) |
| grnd_IDs | Secondary nodes group
identifier. (Integer) |
| grbrc_IDm | Main brick element
| ITIED | Tied option flag.
(Integer) |
- For brick elements (8-nodes, 20-nodes), contact is only considered on face 1-2-3-4 and 5-6-7-8.
- For thick shell elements (8-nodes, 16-nodes), contact only occurs on top and bottom surface (1-2-3-4 and 5-6-7-8).
- The defined nodes must have non-zero mass.
- The following kinematic
conditions can be used with Lagrange Multipliers:
- Interface TYPE16
- Interface TYPE17
- Interface TYPE2
- Interface TYPE7
- Boundary condition
- Rigid body
- Imposed velocity
- Rigid wall
- General joints
- Multi-point constraints
