/INTER/LAGMUL/TYPE17
Block Format Keyword This interface simulates impact between external surfaces of two brick groups. The external surfaces can only be 16-node thick shell (/SHEL16) elements. Lagrange Multiplier conditions are used in this interface.
These kinematical conditions are only compatible with other Lagrange Multiplier kinematical conditions. This interface formulation is not compatible with SPMD parallel version.
| /INTER/LAGMUL/TYPE17/inter_ID/unit_ID | |||||||||
| inter_title | |||||||||
| grbrc_ID1 | grbrc_ID2 | ||||||||
| ITIED | |||||||||
Definition
| inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| inter_title | Interface
title. (Character, maximum 100 characters) |
| grbrc_ID1 | First brick group
identifier (16-node thick shells group). (Integer) |
| grbrc_ID2 | Second brick group
| ITIED | Tied option flag.
(Integer) |
- Both surfaces are defined with two brick IDs and not surface IDs.
- These kinematical
conditions are only compatible with other Lagrange multiplier kinematical
conditions:
- Interface TYPE16
- Interface TYPE17
- Interface TYPE2
- Interface TYPE7
- Boundary condition
- Rigid body
- Imposed velocity
- Rigid wall
- General joints
- Multi-point constraints
