*MAT_ADD_DAMAGE_DIEM
LS-DYNA Input Interface KeywordDefines failure criteria in which damage initiation and damage evolution can be separately defined.
Damage initiation has no influence on the stress computation and damage evolution can lead to stress softening.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_ADD_DAMAGE_DIEM | |||||||
| mat_ID | NINIEVO | PTHICKFAIL | |||||
| INITYPE | TAB_ID | PARAM2 | PARAM3 | ISHEAR | TAB_EL | ||
| EVOTYPE | COMPTYP | DISP | ALPHA | ||||
Definition
| mat_ID | Material
identifier. (Integer) |
| NINIEVO | Number of initiation/evolution
criteria. (Integer) |
| PTHICKFAIL | Failed layers prior ratio to shell
element deletion. (Real) |
| INITYPE | Damage initiation tabulated
criterion type. (Integer) |
| TAB_ID | Failure initiation criterion table
| PARAM2 | Failure initiation criterion
parameter. (Real) |
| PARAM3 | Failure formulation
parameter. (Real) |
| ISHEAR | Take transverse shear components
into account flag. (Integer) |
| TAB_EL | Element size scaling for failure
initiation criterion. (Integer) |
| EVOTYPE | Damage evolution
type. (Integer) |
| COMPTYP | Criterion combination type (only if
NINIEVO > 0). (Integer) |
| DISP | Plastic displacement at
failure. (Real) |
| ALPHA | Exponential shape
parameter. (Real) |
- This keyword maps to /FAIL/INIEVO.
