/MAT/LAW63 (HANSEL)
Block Format Keyword This law describes the trip steel plastic material. This material law can be used only with shell elements.
| /MAT/LAW63/mat_ID/unit_ID or /MAT/HANSEL/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | Cp | ||||||||
| A | B | Q | C | D | |||||
| P | AHS | BHS | m | n | |||||
| K1 | K2 | Vm0 | |||||||
| T0 | Hl | ||||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| E | Initial Young's
modulus. (Real) |
| v | Poisson's
ratio. (Real) |
| Cp | Specific heat
capacity. Default = 1030 (Real) |
| A | Material parameter
1. (Real) |
| B | Material parameter 2.
5 Default = -1.0 (Real) |
| Q | Material parameter
3. (Real) |
| C | Material parameter
4. (Real) |
| D | Material parameter
5. (Real) |
| P | Material parameter
6. (Real) |
| AHS | Material parameter
7. (Real) |
| BHS | Material parameter
8. (Real) |
| m | Material parameter
9. (Real) |
| n | Material parameter
10. (Real) |
| K1 | Material parameter
11. (Real) |
| K2 | Material parameter
12. (Real |
| Material parameter
13. (Real |
| Vm0 | Initial martensite
fraction. Default = 10-20 (Real) |
| Initial plastic
strain. (Real) |
| T0 | Initial
temperature. (Real) |
| Hl | Latent heat of
martensite. (Real) |
| Taylor-Quinney
coefficient. Default = 1.0 (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW63/1/1
Steel
# RHO_I
7.8E-9
# E Nu Cp
210000 .3 460000000
# A B Q C D
.32 .226 1379.4 -2.173 .0084
# P AHS BHS m n
6.25 318.2 2170 2.94 1.39
# K1 K2 DH VM_0 EPS0
1 0 414.7 1E-4 .002
# T0 Hl eta
273 150 0.9
#ENDDATA
/END
- Martensite
fraction rate:
(1) - Martensite fraction:
(2) - Mechanical behavior:
(3) - The temperature is computed assuming the
adiabatic condition (by default the condition is isothermal with
Cp =
1030):
(4) Where, Eint is the internal energy of the element.
- B must
satisfy this condition:
(5) - The Taylor-Quinney
coefficient must satisfy this condition:
(6)
