/MAT/LAW79 (JOHN_HOLM)
Block Format Keyword This material law describes the behavior of brittle materials, such as ceramics and glass. The implementation is the second Johnson-Holmquist model: JH-2.
/MAT/LAW79/mat_ID/unit_ID or /MAT/JOHN_HOLM/mat_ID/unit_ID
mat_title
ρ i ρ 0
G
a b m n
c ε ˙ 0 σ f max * Fcut
T HEL PHEL
D1 D2
K1 K2 K3 β
Definition
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
ρ 0 Reference density used in E.O.S (equation of state).
Default = ρ 0 = ρ i (Real)
[ kg m 3 ]
G Shear modulus
(Real)
[ Pa ]
a Intact normalized strength constant. 1
(Real)
b Fractured normalized strength constant. 1
(Real)
m Fractured strength pressure exponent. 1
(Real)
n Intact strength pressure exponent. 1
(Real)
c Strain rate coefficient.
= 0 (Default)
No strain rate effect.
(Real)
ε ˙ 0 Reference strain rate.
Usually = 1 (Real)
[ 1 s ]
σ f max * Maximum normalized fractured strength.
Default = 1030 (Real)
Fcut Cutoff frequency for strain rate filtering.
= 0
No strain rate filtering.
(Real)
[Hz]
T Maximum pressure tensile strength.
[ Pa ]
HEL Hugoniot elastic limit.
(Real)
[ Pa ]
PHEL Pressure at Hugoniot elastic limit.
(Real)
[ Pa ]
D1 Damage constant. 2
(Real)
D2 Damage exponent. 2
(Real)
K1 Bulk modulus.
(Real)
[ Pa ]
K2 Pressure coefficient. 3
(Real)
[ Pa ]
K3 Pressure coefficient. 3
(Real)
[ Pa ]
β Bulking pressure coefficient 0 < β < 1 .
(Real)
Input Example
  B4C [2] Al2O3 [1]
ρ 0 [ kg m 3 ] 2510 3700
G [GPA] 197 90
a 0.927 0.93
b 0.70 0.31
m 0.85 0.6
n 0.67 0.6
c 0.005 0
σ f max * 0.2 -
T [GPA] 0.26 0.2
HEL [GPA] 19.0 2.8
PHEL [GPA] 8.71 1.46
D1 0.001 0.005
D2 0.5 1
K1 [GPA] 233 131
K2 [GPA] -593 0
K3 [GPA] 2800 0
β 1 1
Example (AL2O3)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW79/1/1
Al2O3
#              RHO_I               RHO_0
               .0037                   0
#                  G
               90160
#                  a                   b                   m                   n
                 .93                   0                   0                  .6
#                  c                EPS0          SIGMA_FMAX
                   0                .001               1E-30
#                  T                 HEL                PHEL
                 200                2790                1460
#                 D1                  D2
                   0                   0
#                 K1                  K2                  K3                BETA
              130950                   0                   0                   1
#ENDDATA
/END
Example (B4C)
/UNIT/1
units_for_example_B4C
                  Mg                  mm                   s
/MAT/LAW79/1/1
B4C
#              RHO_I               RHO_0
            2.510E-9                   0
#                  G
              197000
#                  a                   b                   m                   n
               0.927                0.70                0.85                0.67
#                  c                EPS0          SIGMA_FMAX                FCUT
               0.005                 1.0               200.0             10000.0
#                  T                 HEL                PHEL
                 260               19000                8710
#                 D1                  D2
               0.001                 0.5
#                 K1                  K2                  K3                BETA
              233000             -593000             2800000                   1
  1. The equation describing the normalized equivalent stress is:(1)
    σ * = ( 1 − D ) σ i * + D σ f *
    with the equivalent stress of the intact material:(2)
    σ i * = a ( P * + T * ) n ( 1 + c ln ε ˙ ε ˙ 0 )
    and the equivalent stress of the failed material:(3)
    σ f * = b ( P * ) m ( 1 + c ln ε ˙ ε ˙ 0 ) < σ f max *
    The stresses are normalized to the stress at the Hugoniot elastic limit:(4)
    σ HEL = 3 2 ( HEL − P HEL )
    σ * = σ σ HEL and pressure are normalized to PHEL:
    P * = P P H E L MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaW baaSqabeaacaGGQaaaaOGaeyypa0ZaaSaaaeaacaWGqbaabaGaamiu amaaBaaaleaacaWGibGaamyraiaadYeaaeqaaaaaaaa@3D6D@ and T * = T P H E L MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGubWaaW baaSqabeaacaGGQaaaaOGaeyypa0ZaaSaaaeaacaWGubaabaGaamiu amaaBaaaleaacaWGibGaamyraiaadYeaaeqaaaaaaaa@3D74@
  2. The accumulated damage is:(5)
    D = ∑ Δ ε f p ε f p
    where, the plastic strain to failure is:(6)
    ε f p = D 1 ( P * + T * ) D 2
  3. The Equation of state is: (7)
    P = K 1 μ + K 2 μ 2 + K 3 μ 3 + Δ P
    Where, the bulking pressure Δ P is computed as a function of the elastic energy loss Δ U converted into potential hydrostatic energy:(8)
    Δ P t + Δ t = − K 1 μ + ( K 1 μ + Δ P t ) 2 + 2 β K 1 Δ U
  4. Time history and animation output is available using these USRi variables:
    • USR1: Bulking Pressure Δ P
    • USR2: Old Yield Stress
  5. Strain rate filtering can be used and activated when a cutoff frequency Fcut for filtering is defined.
1 An improved computational constitutive model for brittle materials, G.R. Johnson, T.J. Holmquist, American Institute of Physics, 1994.
2 Response of boron carbide subjected to large strains, high strain rates, and high pressures G.R. Johnson, T.J. Holmquist, Journal of Applied Physics, Volume 85, #12, June 1999.
