/MAT/LAW97 (JWLB)
Block Format Keyword This law describes the Jones-Wilkins-Lee-Baker EOS for detonation products of high explosives.
Where, is relative volume and and are material parameters.
| /MAT/LAW97/mat_ID/unit_ID or /MAT/JWLB/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| P0 | psh | IIBFRAC | |||||||
| D | PCJ | E0 | C | ||||||
| A5 | A2 | A3 | A4 | A5 | |||||
| R1 | R2 | R3 | R4 | R5 | |||||
| AL1 | AL2 | AL3 | AL4 | AL5 | |||||
| BL1 | BL2 | BL3 | BL4 | BL5 | |||||
| RL1 | RL2 | RL3 | RL4 | RL5 | |||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Interger, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| Reference density used in
E.O.S (equation of state). Default = (Real) |
| P0 | Initial
pressure (Real) |
| Psh | Pressure
shift (Real) |
| IBFRAC | Burn fraction calculation flag.
(Integer) |
| D | Detonation
velocity. (Real) |
| PCJ | Chapman Jouguet
pressure. (Real) |
| E0 | Detonation energy per unit
volume. (Real) |
| Parameter of equation of
state. (Real) |
| C | Parameter of equation of
state. (Real) |
| A1~A5 | Parameter of equation of
state. (Real) |
| R1~R5 | Parameter of equation of
state. (Real) |
| AL1~AL5 | Parameter of equation of
state. (Real) |
| BL1~BL5 | Parameter of equation of
state. (Real) |
| RL1~RL5 | Parameter of equation of
state. (Real) |
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
/MAT/LAW97/7/1
JWLB - OCTOL 72/25
# RHO_I RHO_0
1.821 1.821
# P0 PSH IBFRAC
0 0 0
# D PCJ E0 W C
0.85381 .33755 .096034 .30731 .0104772
# A1 A2 A3 A4 A5
909.17 8.9469 .81495 0 0
# R1 R2 R3 R4 R5
15.941 5.4178 2.1956 0 0
# AL1 AL2 AL3 AL4 AL5
65.093 -179.81 156.04 .78487 0
# BL1 BL2 BL3 BL4 BL5
0 0 0 0 0
# RL1 RL2 RL3 RL4 RL5
3.6906 4.52693 5.8014 .95864 0
/ALE/MAT/7/1
0
#enddata
From Reference
Unit System is g, cm, ms, Mbar
| PAX2 | PAX2A | OCTOL 77/25 | OCTOL 70/30 | |
| 1.7370 | 1.770 | 1.821 | 1.803 | |
| E0 | .086116 | .090798 | .096034 | .093757 |
| D | .83460 | .85173 | .85381 | .84120 |
| PCJ | .30502 | .32416 | .33755 | .32528 |
| A1 | 909.13 | 909.14 | 909.17 | 549.98 |
| A2 | 10.513 | 10.195 | 8.9469 | 5.8075 |
| A3 | .92253 | .76191 | .81495 | .041638 |
| R1 | 16.661 | 16.266 | 15.941 | 15.323 |
| R2 | 5.9113 | 5.6415 | 5.4178 | 4.0477 |
| R3 | 2.3618 | 2.1540 | 2.1956 | .62665 |
| C | .011724 | .011325 | .0104772 | .0058269 |
| .35956 | .36989 | .30731 | .27665 | |
| 46.898 | 69.018 | 65.093 | 1.5621 | |
| -215.40 | -176.03 | -179.81 | ||
| 270.22 | 163.48 | 156.04 | ||
| .88536 | .76214 | .78487 | ||
| -.27665 | ||||
| 4.3128 | 4.0339 | 3.6906 | 1.0841 | |
| 5.7197 | 4.8830 | 4.52693 | ||
| 7.318 | 6.5455 | 5.8014 | ||
| 1.0892 | 1.0394 | .95864 |
- JWLB EOS is an updated model from JWL EOS. For further information about JWL parameters, refer to /MAT/LAW5 (JWL).
- JWLB EOS can be degenerated
into JWL EOS using:
; C=0;
