LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNIT card to specify model units.
LS-DYNA Input Interface KeywordThis keyword defines an isotropic, visco-elastic material. It is generally used to model incompressible rubbers, polymers,
foams, and elastomers.
LS-DYNA Input Interface KeywordThis model expresses material stress as a function of strain, strain rate, temperature dependency and plastic strain
failure criterion.
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain
rates.
LS-DYNA Input Interface KeywordThis keyword defines a linear elastic discrete beam material with 6 decoupled degrees of freedom and an optional preload
option.
rates and simple damage model.
LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with 6 degrees of freedom (DOFs). Different loading and
unloading behavior can be specified.
LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with one degree of freedom (DOF). Different loading and
rates. Material thinning and FLD failure are also included.
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material with tension and compression yield stress curves as a function of plastic
strain.
LS-DYNA Input Interface KeywordThis model expresses a three-dimension orthotropic nonlinear elasto-plastic material, usually used to model honeycomb
or foam material.
LS-DYNA Input Interface KeywordThis model expresses a constitutive relation of ductile adhesive materials in 2 modes for normal and tangential directions.
LS-DYNA Input Interface KeywordDefines a rubber and foam material with uniaxial tensile/compression test results as input curve. This material can
be used with solid elements only.
LS-DYNA Input Interface KeywordDefines a perfectly plastic cohesive material with state dependency, normal and shear damage, and normal and shear
failure.
*MAT_001 (ELASTIC) LS-DYNA Input Interface KeywordDefines an isotropic, linear elastic material using Hooke’s law.
*MAT_002 (ORTHOTROPIC_ELASTIC) LS-DYNA Input Interface KeywordThis model expresses a simple orthotropic elastic material.
*MAT_003 (PLASTIC_KINEMATIC) LS-DYNA Input Interface KeywordDefines an isotropic, elasto-plastic material with s Cowper-Symonds strain rate model.
*MAT_006 (VISCOELASTIC) LS-DYNA Input Interface KeywordThis keyword defines an isotropic, visco-elastic material. It is generally used to model incompressible rubbers, polymers, foams, and elastomers.
*MAT_009 (NULL) LS-DYNA Input Interface KeywordDefines a void material without stiffness.
*MAT_015 (JOHNSON_COOK) LS-DYNA Input Interface KeywordThis model expresses material stress as a function of strain, strain rate, temperature dependency and plastic strain failure criterion.
*MAT_018 (POWER_LAW_PLASTICITY) LS-DYNA Input Interface KeywordThis model expresses isotropic plasticity model with rate effects which uses a power law hardening.
*MAT_020 (RIGID) LS-DYNA Input Interface KeywordDefines a rigid material assigned to a part.
*MAT_024 (PIECEWISE_LINEAR_PLASTICITY) LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates.
*MAT_063 (CRUSHABLE_FOAM) LS-DYNA Input Interface KeywordThis keyword defines a crushable foam material with optional tension cutoff and elastic unloading.
*MAT_066 (LINEAR_ELASTIC_DISCRETE_BEAM) LS-DYNA Input Interface KeywordThis keyword defines a linear elastic discrete beam material with 6 decoupled degrees of freedom and an optional preload option.
*MAT_067 (NONLINEAR_ELASTIC_DISCRETE_BEAM) LS-DYNA Input Interface KeywordThis keyword defines a non-linear elastic discrete beam material with 6 decoupled DOFs with an optional preload.
*MAT_068 (NONLINEAR_PLASTIC_DISCRETE_BEAM) LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with 6 decoupled DOFs with an optional preload.
*MAT_071 (CABLE_DISCRETE_BEAM) LS-DYNA Input Interface KeywordThis keyword defines an elastic cable material with no stiffness in compression.
*MAT_074 (ELASTIC_SPRING_DISCRETE_BEAM) LS-DYNA Input Interface KeywordThis keyword defines a nonlinear elasto-plastic discrete beam material with one DOFs and optional preload option.
*MAT_077_H (HYPERELASTIC_RUBBER) LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified from uniaxial experimental data.
*MAT_077_O (OGDEN_RUBBER) LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified using the Ogden material models.
*MAT_081 (PLASTICITY_WITH_DAMAGE) LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates and simple damage model.
*MAT_083 (FU_CHANG_FOAM) LS-DYNA Input Interface KeywordDefines an isotropic, highly compressible Fu Chang foam.
*MAT_091 (SOFT_TISSUE) LS-DYNA Input Interface KeywordThis material is used to represent biological soft tissues such as ligaments based on Mooney-Rivlin formulation.
*MAT_092 (SOFT_TISSUE_VISCO) LS-DYNA Input Interface KeywordThis material is used to represent biological soft tissues such as ligaments based on Mooney-Rivlin formulation.
*MAT_098 (SIMPLIFIED_JOHNSON_COOK) LS-DYNA Input Interface KeywordDefines an an isotropic elasto-plastic material using the Johnson-Cook material model.
*MAT_100 (SPOTWELD) LS-DYNA Input Interface KeywordDefines an elasto-plastic spotweld material for beam element (elform=9) or solid element.
*MAT_105 (DAMAGE_2) LS-DYNA Input Interface KeywordDefines an elastic viscoplastic material model.
*MAT_119 (GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM) LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with 6 degrees of freedom (DOFs). Different loading and unloading behavior can be specified.
*MAT_121 (GENERAL_NONLINEAR_1DOF_DISCRETE_BEAM) LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic discrete beam material with one degree of freedom (DOF). Different loading and unloading behavior can be specified.
*MAT_123 (MODIFIED_PIECEWISE_LINEAR_PLASTICITY) LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates. Material thinning and FLD failure are also included.
*MAT_124 (PLASTICITY_COMPRESSION_TENSION) LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material with tension and compression yield stress curves as a function of plastic strain.
*MAT_126 (MODIFIED_HONEYCOMB) LS-DYNA Input Interface KeywordThis model expresses a three-dimension orthotropic nonlinear elasto-plastic material, usually used to model honeycomb or foam material.
*MAT_138 (COHESIVE_MIXED_MODE) LS-DYNA Input Interface KeywordThis model expresses a constitutive relation of ductile adhesive materials in 2 modes for normal and tangential directions.
*MAT_156 (MUSCLE) LS-DYNA Input Interface KeywordDefines a muscle model for safety applications. Used only with truss elements.
*MAT_177 (HILL_FOAM) LS-DYNA Input Interface KeywordDefines a highly compressible foam based on the strain energy function proposed by Hill.
*MAT_181 (SIMPLIFIED_RUBBER/FOAM) LS-DYNA Input Interface KeywordDefines a rubber and foam material with uniaxial tensile/compression test results as input curve. This material can be used with solid elements only.
*MAT_240 (COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE) LS-DYNA Input Interface KeywordDefines a perfectly plastic cohesive material with state dependency, normal and shear damage, and normal and shear failure.
*MAT_ADD_DAMAGE_DIEM LS-DYNA Input Interface KeywordDefines failure criteria in which damage initiation and damage evolution can be separately defined.
*MAT_ADD_EROSION LS-DYNA Input Interface KeywordDefines a cumulative failure model.
*MAT_B01 (SEATBELT) LS-DYNA Input Interface KeywordDefines a 1D seatbelt material.
*MAT_S08 (SPRING_INELASTIC) LS-DYNA Input Interface KeywordDefines a nonlinear spring material with stiffness available only in tension or in compression.
