/PROP/TYPE2 (TRUSS)
Block Format Keyword This property is used to define the truss property set.
| /PROP/TYPE2/prop_ID/unit_ID or /PROP/TRUSS/prop_ID/unit_ID | |||||||||
| prop_title | |||||||||
| Area | Gapini | ||||||||
Definition
| prop_ID | Property identifier (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| prop_title | Property title (Character, maximum 100 characters) |
| Area | Initial cross section (Real) |
| Gapini | Initial gap Default = 0 (Real) |
- For truss
elements, if
the cross section variation is
computed as:
(1) Where, is the Poisson's ratio given in the material law.
- The truss is
activated only if:
(2) The current distance between truss nodes is smaller than the initial length minus Gapini.
- Gapini should be Gapini > 0. Negative Gapini. will be treated as 0. The truss will not be activated in tensile.
