/SENSOR/SECT
Block Format Keyword Describes the sensors used to activate or deactivate an object according to section force.
| /SENSOR/SECT/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| sect_ID | DIR | Fmin | Fmax | Tmin | |||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| sect_ID | Section
| DIR | Force direction.
(Integer) |
| Fmin | Minimum
force. Default = 0 (Real, maximum 20 fields) |
| Fmax | Maximum
| Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type
SECT:Sensor is activated when section force satisfies the criteria:
- or during Tmin
Dir defines Force direction:- TF
- Total Force
- TM
- Total Moment
- FN
- Normal Force
- FT
- Tangent Force
- FX
- Force in X direction
- FY
- Force in Y direction
- FZ
- Force in Z direction
- MX
- Moment in X direction
- MY
- Moment in Y direction
- MZ
- Moment in Z direction
- Values for force and moment component limits in the force-based sensors (SECT) can be positive and negative. Normal, tangent, total force and moment values are always positive.
