Adding a Change List
To add a change list
  1. On the Navigation Tree, click Server Library, and select Change Lists.
  2. Click add button on the Change Lists page. The Change Lists page appears.
  3. Enter the name of a change list file in the Name field.
  4. Enter the description of a change list in the Description field. This step is optional.
  5. To enter the path to a change list file in the Change List field, click the Browse button, and select a change list file.
  6. Enter any comments if necessary in the Comment field.
  7. Assign the change list to a new or existing folder in the Assign to Folders field. To add the change list to a new folder, click Create New Folder.
  8. To save a change list, click Save.
    The system saves the new change list to the database and displays the updated Change Lists page, if the operation is completed successfully.
  9. To reset the recent changes, click the Clear button.
  10. To cancel the operation and return to the Change Lists page, click the Cancel button.
To upload a change list
  1. On the Navigation Tree, click Server Library and select Change Lists.
  2. Click Upload Change Lists on the Change Lists page.
  3. Click Add Files to browse to a change list file or drag and drop change list file in the Drop files here area.
  4. To save a change list, click Save.
  5. To reset the recent changes, click the Clear button.
  6. To cancel the operation and return to the Change Lists page, click the Cancel button.
