Adding a Project File
To add an existing project file created with Monarch
  1. On the Navigation Tree, click Server Library and select Projects.
  2. On the displayed page, click the Add icon (add button) . The Project page appears.
  3. On the Project page, fill out the following fields:
  • Name: Enter the name of a project file.
  • Description: An optional description of a project file.
  • Project: Displays the path to a project file, after you click the Browse button and select a model file.
  • Comment: Enter any comments if necessary.
  • Assign to Folders: Adds the project file to a new or existing folder. To add the project file to a new folder, click Create New Folder.
  1. Click the Browse button next to the Project field to select a project file to upload.
  2. Click Save. The system adds the new project file to the database and displays the updated Projects page, if the operation is completed successfully.
To add multiple projects
  1. Click the Upload Project button.
  2. Click the Add files ... button and select your project files, or
    Select and drag and drop your files your files in the Drop files here area
  3. Click Save. The system adds the new project file to the database and displays the updated Projects page, if the operation is completed successfully.
