Adding a Schedule
A schedule is used to specify when, and at what interval the process will run.
To add a new schedule for a process
On the Schedule tab, click
Select the Suspended check box if you want to suspend the task.
Select the task execution frequency from the following options: One Time, Hourly, Daily, Weekly, Monthly.
Set the time you want the process to run.
Set the start date of the process.
Select the appropriate timezone from the drop-down list.
Click the Save button, to save the schedule or Run Now to start the task immediately.
