Assigning Storage Volumes to Storage Groups
After adding a storage volume you can assign it to a storage group. If no storage groups exist, you will need to create one and then add the storage volume to it.
To assign a storage volume to a storage group
  1. On the Navigation Tree, click Report Warehouse, then click Storage and select Storage Groups.
  2. Click the name of a storage group you want to add a volume to or click anywhere on its row and then click clip0003.
  3. Drag a storage volume from the Available Storage Volumes pane to the Assigned Storage Volumes|Copy# pane.
  4. Under the Assigned Storage Volumes | Copy #, select either #1 or #2 to specify a copy number for the volume.
  5. To assign the volume to the group, click Save.
