Deleting a Change List
You can delete a change list from the system via the Change Lists page.
To delete a change list from the list
  1. On the Navigation Tree, click Server Library and select Change List.
  2. Click clip0053 at the end of the row with the change list you want to delete. A dialog box appears.
  3. Click Delete to delete the change list from the list.
NOTE: If a change list has the Locked status (Model locked), it cannot be deleted. First unlock the change list and then try again.
