Deleting a Model
You can delete a model from the system via the Models page.
To delete a model from the list
  1. On the Navigation Tree, click Server Library and select Models.
  2. Click clip0053 at the end of the row with the model you want to delete. A dialog box appears.
  3. Click Delete to delete the model from the list.
NOTE: If a model has the Locked status (Model locked), it cannot be deleted. First unlock the model and then try again.
