Deleting a Project File
To delete a project file from the list
  1. On the Navigation Tree, click Server Library and select Projects.
  2. Click clip0053 at the end of the row with the project file you want to delete. A dialog box appears.
  3. Click Delete to delete the project file from the list.
NOTES:
If a project file has the Locked status (Model locked), it cannot be deleted. Unlock the project file first and then try again.
If a project file is being used in a process, it cannot be deleted. Instead, a warning message pops up: "There are objects that use this item: Processes: <Process Name>."
