Deleting a Template
You can delete a template from the system via the Templates page.
To delete a template from the list
  1. On the Navigation Tree, click Server Library and select Templates.
  2. Click clip0053 at the end of the row with the template you want to delete. A dialog box appears.
  3. Click Delete to delete the template from the list.
NOTE: If a template has the Locked status (Model locked), it cannot be deleted. First unlock the template and then try again.
