Editing a Custodian Schedule
When you open a saved Custodian schedule for editing, the following tabs become available:
  • Custodian Schedule: On this tab you can edit the schedule. For details about how to change the Custodian schedule, please refer to Adding a Custodian Schedule.
  • Settings: On this tab you can specify the schedule settings.
The following settings are available:
  • Delete the task if it is not scheduled to run again: Deletes the task after it has successfully run.
  • Stop the task if it runs for n hour(s) n minutes: Specifies a run duration limit, which will stop the task after the specified number of hours and/or minutes has passed.
